<img height="1" width="1" style="display:none" src="https://www.facebook.com/tr?id=1500520490268011&amp;ev=PageView&amp;noscript=1"> Prima prova nuova 1er | Il Forum di Quattroruote
BMW 1 Series 120d First Drive
The new 1-series is a car that looks as if it?s been steered, albeit carefully, in the right direction. The press material talks less about dynamic rear-driven handling, and at reassuring length about enhanced comfort and accommodation, improved efficiency and new-to-the-class technology. Which is a good start.
Longer than the old car by 85mm, the new One has a wheelbase that?s been enlarged by 30mm, with 21mm of that extra inter-axle length gone to additional rear legroom. Both tracks have been widened too, by a natch over 40mm at the front axle, and over 60mm at the rear.
Although it?s grown, the new car is 30kg lighter than the old one: would have been 60kg, but climate control now comes as standard. And a thorough structural redesign means the car?s body-in-white is now more than 30 per cent more torsionally rigid across the front bulkhead. That?s good news for ride and handling, too.
Adrian van Hooydonk?s styling update hasn?t cured the ungainly proportions of BMW?s smallest model, but the net effect is a clear improvement. The new car looks lean, more aggressive than the last. The biggest aesthetic bugbear remains the car?s profile, though. Short, tall and backward leaning, it still looks awkward: like a gangly pup that?s had the carpet pulled out from under its paws.
Developed in tandem with the new 3-series, the new 1-series, like the last, has all-independent suspension: MacPherson struts up front and a five-link rear end. The car will be sold exclusively with turbocharged engines: two flavours of directly injected, twin scroll turbocharged 1.6-litre petrol power will be offered from launch (135bhp for the 116i and 168bhp for the 118i), and three 2.0-litre commonrail diesels (ranging from the 115bhp 116d up to the 181bhp 120d).
With 280lb ft of torque from 1750rpm, performance from the 120d is as strong as you?d hope: 60mph comes up in around seven seconds. The powertrain?s all the more exceptional because, fitted with ZF?s excellent eight speed automatic gearbox as an option and BMW?s Efficient Dynamics fuel-saving ancilliaries as standard, the car emits less than 120g/km of CO2. This is a car capable of bettering both 140mph and 60mpg; not at the same time, of course, but remarkable from the same car.
Open the driver?s door, lift your feet over the raised sill, and one or two signs of sophistication begin to show themselves. Material quality?s that bit more consistent in here than it used to be; the plastics around the door pulls, storage cubbies and steering column look much less cheap. Elsewhere the mix of trim on the fascia is varied and attractive ? with one exception. Our ?Urban? spec car came with glossy white plastic highlights on the centre console, door handles and dashboard that look like offcuts from Apple?s iMac storage cupboard. Thankfully the same trims are available in gloss black, which would certainly compliment the rest of the interior better.
It?s still no packaging marvel, but the second-gen 1-series has enough head- and kneeroom for average-sized adults to sit line-astern in the two rows. You can be well over six feet tall and sit comfortably in the front. Getting in and out of the back is still something of a contortion routine, but once aboard bigger passengers can find reasonable comfort provided the front seats are sympathetically positioned. In short, a VW Golf is a considerably more practical car, but the 1-series may now be big enough to put up with ? just.
Would it matter, though, that this new car was bigger, faster, classier and more efficient, if dynamic-centric BMW hadn?t also made it significantly better to drive? Well, the new 1-series is a notably more accomplished dynamic performer than its predecessor, for sure. But it?s still no class-leader.
Conjure up the memory of the last 1-series - of heavy steering shot through with understeer, and a tame chassis that lacked both balance and poise - and this new BMW seems a big achievement. Even on standard springs and passive dampers, it remains a fairly firmly sprung car. It still feels a little short of wheelbase and relatively tall of body at times; has a tendency to gently pitch fore and aft over larger lumps and bumps in a way that a car with a lower, longer profile wouldn?t. But it?s not without decent bump absorption or compliance, and equipped with BMW?s adaptive dampers set to ?Comfort? mode it?s softer still, yet only loses Munich?s trademark feeling of tautness on the worst surfaces.
Even with an electromechanical power-assisted rack the new 1-series steers with less effort and greater fluidity than the old car, and turns into corners more keenly. Those wider tracks have dialled out a lot of body roll along with some understeer. And there are more improvements besides.
So why no overall ringing endorsement? Because ? and this is the bit that BMW really needs to heed ? even counting the ?perfect weight distribution? and ?standard drive?, we could name a dozen front-driven hatchbacks that each offer a much more involving at-the-wheel experience.
The original 1-series? mechanical layout added almost nothing to the car?s handling; this new 1-series may feel more precise, more composed and less remote than the last, but it suffers with the same fundamental problem. It?s too tame, too unengaging to properly represent its maker?s perennial universal selling point. Its course through a fast bend isn?t responsive to adjustment via either brake or throttle pedal. Up your pace on a twisting backroad and, while other rear-drivers come alive, this one remains docile and inert.
Should I buy one?
BMW says that 70 per cent of 1-series buyers are new to the brand, and if that?s true, maybe the car?s main failing isn?t so critical. More rounded dynamics, greater refinement and usability, some great powertrains and a more appealing driving environment make this a 1-series that?s much easier to recommend against its peers, after all.
But it?s still not a great-driving BMW; doesn?t distinguish itself from other cars in the class with the entertainment you expect from a car with a blue-and-white propeller on the bonnet. And now you wonder if an ordinary 1-series hatch ever will.
http://www.autocar.co.uk/CarReviews/FirstDrives/BMW-1-Series-120d-5dr-Hatchback/258168/
Meglio della precedente, ma ancora non al vertice della categoria, secondo Autocar.
Se è meglio della precedente siamo a posto! :D
La Serie 1 l'ho avuta come auto sostitutiva ed è divertentissima da guidare sulle nostre strade.... si ha la sensazione di poterla perfino far girare su se stessa talmente è agile e reattiva e tagliente.
Fancar_ ha scritto:
renexx ha scritto:
Aspetto di sapere quale sia il vertice della categoria, allora....
Saranno le versioni speciali come Megane RS o la Focus RS, quest'ultima per gli inglesi è intoccabile.
Perchè gli inglesi si ricordano ancora di questa:
http://www.uniquecarsandparts.com.au/car_info_ford_escort_rs1600.htm
come di quando avevano un Impero... :D
Recensione di EVO per la 118i
Voto: 4/5
Meglio della precedente per loro. Dubbi sullo stile ed i prezzi.
What is it?
BMW's new entry-level hatchback, packed with more gadgetry than ever, including new engines and lots of 'big car' kit, but still rear-wheel drive and still a decent drive. Prices start at £19,375 for the basic 116i ES with sales kicking off in September.
Technical highlights?
The whole car is 85mm longer and the chassis gets a 30mm stretch in the wheelbase, plus wider front and rear tracks and new damper mountings for the McPherson struts, claimed to give the suspension more compliance.
Only a limited engine range will be available from launch with 1.6-litre petrol and 2.0-litre diesel 'Twinpower' motors that use variable valve timing and a clever Twin Scroll turbo that makes more efficient use of the exhaust gases.
We tried the fastest petrol from launch, the 170bhp 118i, which does 0-62mph in 7.4 seconds, has plenty of low-down torque yet likes to rev and returns (an official) 48mpg combined. It's a great unit.
As for transmissions, there's a new eight-speed automatic gearbox too, which is swift, efficient and comes with steering wheel paddles, but it costs £1,600 so we'd stick with the notchy but precise six-speed manual.
All cars come with Drive Performance Control, which gives you four ?modes? to choose from. These include Comfort ? the standard setting ? and Sport ? which sharpens the steering, throttle and suspension, while Sport + allows more rear wheel slip. The fourth is ECO PRO, which helps save fuel, by adjusting throttle response and limiting use of the air-con, heated mirrors and seats. The idea is that it helps boost economy without you even realising it.
Inevitably lots of big car gadgets have migrated from further up the BMW range, including lane departure warning, adaptive cruise control and Internet access (all available as options.) UK buyers can add Adaptive M Sport suspension for an extra £750 too.
What's it like to drive?
Much better than the old car, which suffered from overly heavy steering and never felt as engaging as it could have done. The new electric power steering system is one of the best so far, telling you all you need to know about what the front wheels are doing.
It's a decent steer, too - with keen turn-in and well contained body roll. On a twisty, bumpy road the 1 grips hard and feels impressively agile. BMW says that its engineers visited north Wales during the car's development to tune the suspension for the unique challenge of British tarmac. And on first impressions it seems to have worked ? springing is still on the firm side but even cars with Sport suspension are far better than the outgoing model, although we'll reserve judgement until we get one here.
Factor in refined motorway manners and a great driving position and the 1-series promises to be a pleasure to drive even when you aren't going for it.
How does it compare?
Well, at the moment it looks set to go straight to the top of its class, although both of its compact premium rivals - the Audi A3 and Mercedes A-Class - are on the verge of receiving their pensions. Of course, for those prepared to forego a posh badge the 1-series also faces some very tough competition from the hot hatch elite, especially given its steep pricing.
Anything else I should know?
Despite that increase in wheelbase, it's still pretty cramped in the back ? a Golf is far more spacious. BMW has made a big effort with personalisation, though, offering two new Urban and Sport trims. We'd go for the former, as it gets sports suspension and 17-inch alloys among other items. Urban looks very 'European' with its dubious white wheels and white wing mirrors/grille slats.
Most buyers will go for the M Sport version, though, which comes with a bodykit and M-badged kit such as wheels, steering wheel and seats.
From 2012, a 99g/km 116i is launched which will be a boon for company car drivers. After that, expect the three-door 1-Series to arrive later in the year, but don't hold your breath for a Coupe or a Convertible - they aren't due until 2013 at the earliest. Don't even ask about a replacement for the just-launched 1M Coupe ? that will happen engineers say, but it's years away.
Concordo per il giudizio sul prezzo, veramente esagerato, personalmente comprerei meglio un X1, che come tutti i SUV garantisce una tenuta del prezzo di rivendita nell'usato notevole.
Commento finale delle prime impressioni di guida di QR:
"Prestazioni, piacere di guida e confort, tutto insieme: difficile pretendere di più."
Direi che non c'è altro da aggiungere......., o meglio ci sarebbe ma evito per carità di patria (industria dell'auto italiana)
116d allestimento Sport con cerchi da 16", interni in stoffa e 116 cavalli alla modica cifra di 30 k? (senza metallizzato, ovviamente).
E' la mia preferita!
Se me la paga l'azienda me la compro...:D
io ho una 123d msport.
ho provato a configurare una 120d ed ho raggiunto i 41k euro.
ma allora quanto costerà la nuova 123d?
oltre 45k???
davvero troppo
A pari motore, i 5000 euro in più che costa rispetto alla G10 li spendo molto ma molto volentieri. ;)
"Solo" 5000 rispetto al 1.6 MJ (che andrà pure un po' meno, per carità)? Non credo...
Stando al listino su QR, si poi ovviamente dipende da quanti "giocattoli" uno ci mette sopra.
Utente_1559185261
